5sge
5sge
Postby phrogmodz » Fri May 20, 2005 9:42 pm
im in the process of building a 5sge at the moment.
i have a 5sfe block and a 3sge head.
anyone done this before?
the factory 5s pistons are dished with collets
cut out for valve clearances and the 3s pistons have raised
tops with collets.
what im after is factory compression ratios for the two engines
and a compression ratio of the hybrid if anyone has gone
down this track before.im avoiding cc ing the heads to calculate
the ratio or doing 1mm oversize mr2 pistons if i dont need to.
1997 sxv10 5sfe
1992 sw20 3sge
thanks
1992 ln130 surf 2jz
nz ae101 wagon
phrogmodz
Postby Akane » Fri May 20, 2005 11:21 pm
Have you checked the yank mr2 board? There's a full write up on what you need to make your 3S-GTE into a 2.2L stroker with the 5S block, so it's pretty much the same to what you're doing, since IIRC, Nemesis did say the 3S-GE head is almost identical to the 3S-GTE head.
Postby phrogmodz » Sat May 21, 2005 2:49 pm
no i havent,
got a link?
1992 ln130 surf 2jz
nz ae101 wagon
phrogmodz
Postby Akane » Sat May 21, 2005 8:16 pm
Postby phrogmodz » Sat May 21, 2005 10:02 pm
cheers for that
1992 ln130 surf 2jz
nz ae101 wagon
phrogmodz
Postby Twolitre » Sat May 21, 2005 11:47 pm
3SGE CR = 10:1 although not to sure about the 5S-FE, probably very slightly less if not the same.
Twolitre
