short shifter isnt short?
Postby phatman3801 » Fri May 20, 2005 9:47 am
i just got my old shifter out and compared to a shortsifter a purcahsed from driven perfromance it was listed as one for 1993 corolla onwards, on thing is when i compare to the orignal shifter it seems near identical! correct me if im wrong but i shoft shifter works by the pivoit point being move so from the pivot ball it shoud be longer than the orignal right?
phatman3801
Postby blitza » Fri May 20, 2005 10:14 am
well the distance between the pivot ball and the linkage mounting should be shorter, perhaps you already had one?
MAD Industries Limited
'97 GTT auto, -under rebuild, again.
the faster you go, the quicker you get there...
blitza
Postby AceSniper » Fri May 20, 2005 11:42 am
yea, I had/Have this same problem...
Brought one from FBI it was exactly the same as the factory one I removed the only dif was it was missing the two pin holes half way up it so that little spring/ball latch thing couldnt be installed onit, mines still on there coz it was such a bitch to pop the plastic links on I couldnt be stuffed taking them back off, emailed FBI about it and they just offered a store credit if I returned it (I havent since im in ham)
AceSniper
Postby Dell'Orto » Fri May 20, 2005 11:46 am
One of the Palmy guys had this problem the other day too...bought a short shifter off JRS, and when we took the old one out, the "short shifter" was actually longer.
I bought a TRD one, its mint 8)
Postby AceSniper » Fri May 20, 2005 12:10 pm
Mmm, Boost wrote:the "short shifter" was actually longer.
you mean longer as in longer throw im guessing, now longer load arm (like it should have)
all I can think of is... do nanna rollers have longer throw than the sportyer versions of the cars... so the short shifters been sold are made for the nannas?
AceSniper
Postby phatman3801 » Fri May 20, 2005 2:09 pm
yea the throw seems the same as factory as expected as the distace from bootom to povit point is same distance! took dam ages to get access to that shifter to! arr annoying just a wastre of my time :evil:
phatman3801
Postby toyonut » Fri May 20, 2005 5:42 pm
blitza wrote:well the distance between the pivot ball and the linkage mounting should be shorter?
it should be longer, not shorter.
toyonut
Postby phatman3801 » Fri May 20, 2005 6:56 pm
yep thats what i thought but it appers its the same...
phatman3801
Postby Dell'Orto » Fri May 20, 2005 10:03 pm
AceSniper wrote:you mean longer as in longer throw im guessing, now longer load arm (like it should have)
No, longer as in the shaft ABOVE the pivot was substantially longer than the factory one, and the shaft below was identical length.
Postby XSVWGN » Sat May 21, 2005 12:14 am
put an add up on the forums for a trd short shifter and see what sort of reponce u get...
I have a short shifter in my ae101 levin gearbox and it makes a shit load of difference and it is alot shorter
2008 Kia rio - work car
XSVWGN
Postby Mr Revhead » Sat May 21, 2005 11:02 am
no need tp put an add up..... we all know who the TRD supplier is around here :wink:
Postby RedMist » Sat May 21, 2005 1:14 pm
Yep, Sollitts should be able to sort you out. :P
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby phatman3801 » Sat May 21, 2005 7:21 pm
well trd ones are out of my price range! any one no where i can score a cheaper one?
phatman3801
Postby Mr Revhead » Sat May 21, 2005 7:55 pm
redmist: who?
phatmna, if you cant afford a proper one, make one, all you need to do is extend the lower portion of the lever and space up the mount the same amount....
Postby toyonut » Sun May 22, 2005 11:21 am
what does the shifter look like, (pic if possible), do the linkages come off the bottom of the shifter (below the pivot) or above the pivot, but yeah any fabrication shop will be able to make one up with a spacer for you, and you may as well modify the factory one while you have the "short" shifter in, then return the short shifter.
toyonut
