Identifying W series Gearboxes
Postby Twolitre » Tue May 10, 2005 5:43 pm
Is there any way of differentiating between a W55, W56, W57, W58 besides pulling apart and checking ratios? I'm just curious as to whether or not my car actually has a W55 in it like what the firewall says.
Twolitre
Postby Silent Knight » Tue May 10, 2005 6:09 pm
Steel sandwich plate only came out on W58s and they are the later model out of the MK3 Supras.
Alloy W58s only came out in the MK2 Supras.
All other W series boxes as far as I know are Alloy. Shouldn't the gearbox itself have a buildplate on the side of it that says what series the box is?
Silent Knight
Postby vvega » Tue May 10, 2005 6:09 pm
sorry mate turns ffrom input to tails shaft is the only way to check the ratios withou pulling it apart
could prolly do this in car even with the rear wheels jaacked
v
vvega
Postby Dangerous_Driver » Tue May 10, 2005 9:54 pm
vegga is right there plus u can tell a 56 from the rest as its a 4wd box!!
My sister can do a better standy!!!
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1365
Dangerous_Driver
Postby KinLoud » Tue May 10, 2005 10:16 pm
Best guide... If it's still in the car
- put gearbox in 1st gear
- get some twink (white typo correction fluid stuff)
- make a mark on the drive shaft and a matching mark on the tailhousing of the gearbox.
- make another pair of marks on the timing pulley etc.
- turn crankshaft and count how many turns
- assistant under car yells when driveshaft has done exactly one rotation.
- about 3.3 turns = W57 or W58 (might be able to tell W57 from W58 by comparing 5th gear ratios W57 0.85, W58 0.78 )
- about 3.6 turns = W55
- about 3.9 turns = W56 or W59, they differ in 3rd gear ratio only (might be 4wd sometimes but I have seen several rwd ones behind diesels)
Out of the car - similar technique but easy to do on your own.
All W gearboxes look the same from the outside except for gearlever position. No way to tell what ratio unless you do the above.
Ken
Hamilton
021 408 863
Postby Gx71man » Thu May 19, 2005 8:43 pm
Silent Knight wrote:Steel sandwich plate only came out on W58s and they are the later model out of the MK3 Supras.
my w55 has a steel bit inbetween the alloy bits, alloy w58s come out of the jza80 2jzge 5speed as well.
I Give My Mrs A 1/4 inch at a time, For those ten seconds or less Im Free...
Gx71man
Postby Silent Knight » Sat May 21, 2005 4:30 pm
Yea but they are remote shift.
He won't have a 58 out of an MKIV in his car wich is why I left those out :wink:
Silent Knight
Postby Gx71man » Sun May 22, 2005 5:37 pm
Silent Knight wrote:Yea but they are remote shift.
oh (damn) Thats quite buzzy.
Gx71man
Postby TygerTung » Mon May 23, 2005 1:54 am
To make it easier to turn over the engine, take out the sparkplugs.
TygerTung
Users browsing this forum: Google [Bot] and 1 guest
