Cusco LSD spider gears
Postby lochbzr » Thu May 26, 2005 10:54 am
hi im looking for spider gears for an ae111 toyota levin 6 speedbox
the model of the lsd is cusco
my current lsd's 4 spider gears has little pits and pieces missing out of the spider gears and it causes alot of noise, after pulling it down only these gears are the prob
where online has these gears and how much do they cost and do they ship to the caribbean?
will post pics soon
lochbzr
Postby lochbzr » Thu May 26, 2005 12:40 pm
lochbzr
Postby Mr Revhead » Thu May 26, 2005 1:00 pm
Postby atmosports » Thu May 26, 2005 7:51 pm
Try cusco direct as above. If you have no luck then you could try through our NZ agent/dealer if you don't have one over there. Brain at Maz-Sport Cusco is the guy to talk to here, http://www.maz-sport.com/
by phone: Ph: (09) 414 1901
by email: mazsport@xtra.co.nz
I've tried dealing with cusco before for things & they will generally put you back onto the agent in your area even if you've already tried them & they haven't been able to help.
atmosports
Postby lochbzr » Thu May 26, 2005 8:39 pm
thx emailing now
lochbzr
Postby TygerTung » Fri May 27, 2005 2:32 am
Do cusco make a U code LSD?
TygerTung
Postby lochbzr » Fri May 27, 2005 2:41 am
whats a U code lsd?
lochbzr
Postby spencer » Fri May 27, 2005 11:41 am
TygerTung wrote:Do cusco make a U code LSD?
Thats a big negative
ms63 crown
spencer
