AE86 splines/axles gearbox tec. questions
Postby AE85coupe » Tue Mar 09, 2004 3:36 pm
Could somebody explain to me the difference in splines or axles or whatever in the different year ae86's?
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby JT » Wed Mar 10, 2004 11:04 am
Early model AE86's ('83-'84) use 21 spline diff's and the later models (facelift shape? '85-87) use 23 spline. Rob_gtz will correct me if im wrong :)
JT
Postby Rob_GTZ » Wed Mar 10, 2004 6:13 pm
Yep JT is right, axle has more Teeth & also larger in diameter
Rob_GTZ
Postby Chrislost » Tue May 31, 2005 3:26 pm
so where do 22spline ones come from :S
Chrislost
Postby JT » Tue May 31, 2005 5:33 pm
Chrislost wrote:so where do 22spline ones come from :S
The T-50 gearbox, fitted to rwd 4AGEs has a 22 spline output shaft
JT
spline
Postby crispy'86 » Tue May 31, 2005 6:59 pm
Yes but don't forget JT, t50's from 2tg's also come out with 22 spline gearboxes too.
crispy'86
Re: spline
Postby Rick » Tue May 31, 2005 7:29 pm
crispy'86 wrote:Yes but don't forget JT, t50's from 2tg's also come out with 22 spline gearboxes too.
You mean they came out with 20 splines
Postby AE85coupe » Tue May 31, 2005 7:44 pm
no some 2tg's had 22 spline t50's as well, i have one sitting in my shed at the moment
Details of car here
AE85coupe
Postby spencer » Wed Jun 01, 2005 11:08 am
AE85coupe wrote:no some 2tg's had 22 spline t50's as well, i have one sitting in my shed at the moment
yea the 22 spline is more to do yith the year of production maybe than behind a certain car. 3a carinas have a 22 spline so do some 2tg's as said. Also I posted this up before somewhere
ms63 crown
spencer
