spark plug gap
spark plug gap
Postby LEV_101 » Sun Jun 12, 2005 3:58 pm
i got some spark plugs and the box says " do not adjust spark plug gap due to extremely fine center electrode." what does this mean ? and what does the gap do ? can someone please explain this to me :D thanks
LEV_101
Postby ROBODISCO_20v » Sun Jun 12, 2005 6:28 pm
The gap is the distance between the the centre electrode and the ground electrode. By the sounds of it you have got iridium plugs as they have an extremly fine centre electrode. Now days you don't have to worry about gapping plugs as the come preset from the factory.
The link below should help you more.
http://www.ngk.com/sparkplug411.asp
ROBODISCO_20v
Postby matt dunn » Sun Jun 12, 2005 8:09 pm
All i do at work when we fit plugs is pick up the first one and visually compare the gap against the rest of the set. If they are all the same them bang them in.
Just in case one has been dropped while in the box etc.
Matt
Postby Rob » Sun Jun 12, 2005 8:28 pm
I like it. Bang em in I say. If it say don't adjust then don't
1990 ST185H - project
1996 VS Acclaim wagon
Rob
spark plug gap
Postby jondee86 » Sun Jun 12, 2005 9:16 pm
The spark "jumps" across the gap and ignites the air/fuel mixture
in the combustion chamber. Increasing the width of the gap makes
it more difficult for the spark to jump across, and can lead to
miss-firing under load. The gap tends to "grow" on old plugs as
the metal is eroded away, plus it is harder for a spark to jump
from a rounded edge.
That is why you changes your plugs :wink:
Cheers.... jondee86
Watch this space >>> <<<
jondee86
