sliver top into aw11 mr2
Postby blue-smoke » Fri Jun 03, 2005 6:20 pm
can some one help me , i want to put a sliver top into a aw11 mr2 and i want to know about engine mounts and the whole process in putting it in
blue-smoke
Postby CaM » Fri Jun 03, 2005 6:30 pm
should bolt straght in using your old mounts
wiring will be the only "hard" part... rest is childs play
CaM
Postby 85AW20v » Fri Jun 03, 2005 6:39 pm
YepCaM is right. Water lines go backwards to what you think but you can still use all the blue top bits - just have to rearrange them. You'll need to lengthen the silvertop extractors by about 40mm to clear the starter motor and use the thin plate that goes behind the flywheel, from the blue top. Silvertop flywheel and clutch fit the std gbox and as far as I remember the std mounts work as does the throttle cable if you rearrange the where it comes out to above the crossmember behind the fuel tank rather than underneath it. Wiring is a bit of a nuisance but not too hard if you have wiring diagrams.
Have fun!! Its great fun when you're finished!!
See ya
Simon
85 MR2 20v
85AW20v
Postby Mr Revhead » Fri Jun 03, 2005 6:39 pm
you will have issues with the starter, if its on the exhaust side. need to mod no 1 runner to clear.
Postby MR2boy » Fri Jun 03, 2005 6:43 pm
Mr Revhead wrote:you will have issues with the starter, if its on the exhaust side. need to mod no 1 runner to clear.
sometimes, seems to be luck if you need to modify it or not, mine fit without modification so check it first
**** Car here ***
MR2boy
Postby vvega » Fri Jun 03, 2005 9:53 pm
grinding the flange works well
as thats the part that wont clear the starter
or.... use a ae-92 starter....
or use the 20v gearbox front housing and put the starter on the back....
v
vvega
Postby blue-smoke » Sat Jun 04, 2005 4:41 pm
thanks for the info , im going to get my hands on a silver top then do the pistons and cams and shit like that then bolt it on so it might take awile but it will be laceing skids around chch when its done
blue-smoke
Re: cheers
Postby MR2boy » Sat Jun 04, 2005 4:47 pm
blue-smoke wrote:it will be laceing skids around chch when its done
lets hope not, enough idiots doing that down here already
**** Car here ***
MR2boy
Re: cheers
Postby Dell'Orto » Sat Jun 04, 2005 8:31 pm
great way of getting rid of another one ;)
Postby blue-smoke » Mon Jun 13, 2005 3:58 pm
na im just jokeing , safer on a track .
blue-smoke
