2e and 2e-e differences???
Postby crispy'86 » Sat Jul 02, 2005 1:31 pm
This will test you 2e gurus, what are the differences between the 2. I know the 2e-e is injected but are the heads the same or different for the efi manifold to bolt to??? pistons same or different??? And all the internals are they the same????? between 2e carb'd and injected
crispy'86
Postby Stu- » Sat Jul 02, 2005 6:47 pm
Same rods and pistons. Carb head has the injector positions filled and fuel pump position milled open where the EFI one is opposite. I'm fairly sure the cam is the same too. Just drill the injector holes open and make a blanking plate for the fuel pump if your converting to EFI.
Project Thread
Stu-
2e
Postby crispy'86 » Sun Jul 03, 2005 1:17 am
i thought the injectors were inthe manifold. just finding out info for workmate thinking of using 2ee into his g/f's car. thinking of swapping engines in her car while one gets rebuilt.
crispy'86
Postby Stu- » Sun Jul 03, 2005 12:09 pm
They're in the head.
Project Thread
Stu-
2e
Postby crispy'86 » Mon Jul 04, 2005 6:51 pm
cheers for that!! :D
crispy'86
Postby Stu- » Mon Jul 04, 2005 7:18 pm
No problem :D
Project Thread
Stu-
