Supra brakes....
Supra brakes....
Postby blackmk3 » Wed Aug 03, 2005 10:32 pm
the brakes are pretty shagged on my MA70 given any chance she will give you fade neway im just curious would SZ-RZ brakes fit? my "limited" factory brakes are big but from what ive heard they still get fade...weight :roll:
are they a straight bolt up, or what do i need to change
break master?
also...what is the diffrence between a "G" series and a "M" series LSD supra diff?
if anyone can help that would be great
Thanks
Nick
Mk3 MA70 Supra
blackmk3
Postby sry_not4sale » Thu Aug 04, 2005 2:53 pm
Farken whales :lol:
1983 Mazda Cosmo 12at
sry_not4sale
Postby Silent Knight » Thu Aug 04, 2005 3:07 pm
Nope neither of those two are bolt on replacements for an MK3. Better option would be if you don't already have them to upgrade to the bigger MA70 brakes as they are bolt on replacements and will do the job. :wink:
Silent Knight
Postby sry_not4sale » Thu Aug 04, 2005 3:09 pm
What do the other mk3 owners on this forum say? With good pads, new discs and quality fluid do the big wide whales pull up ok?
sry_not4sale
Postby Jebus » Thu Aug 04, 2005 6:26 pm
What pads were you running?, get a descent set of lucas race pads (very good, arent as rough as metal kings but perform just as good) Descent Dot 5.1 fluid and give the discs a machine. A newish model supra shouldnt have braking issues unless its set up wrong?
Jebus
Postby blackmk3 » Thu Aug 04, 2005 7:11 pm
Silent Knight Posted: Thu Aug 04, 2005 2:07 pm Post subject:
yeah i do have the bigger MA70 brakes, the rotas are origional and pretty nasty im going to replace them but i just thaught id investigate them anyway, the pads are just nasty repco replacemets as far as i know (previous owner)
so recomend, new rotors 5.1 fluid and lucas pads?
what about slotted rotors? worth it?
Nick
Mk3 MA70 Supra
blackmk3
Postby Jebus » Thu Aug 04, 2005 7:15 pm
The slots disperse heat better so it helps them stay cool and ultimately stop fade, while looking the bizzo behind your wheels. But if its set up with nice pads and descent fluid id suprised if it still faded.
If theres still heaps of meat on the discs they can be machined back to smooth for about $30 a pair, or get some aftermarket slotted ones, if the wallet allows :D
Jebus
Postby blackmk3 » Thu Aug 04, 2005 7:39 pm
wallet always allows for my supra!
i think i will go slotted, what brands are to stare clear of?
DBS is what? i hear ther crap but i also hear from other people that they are good..
or is there another brand out there?
Mk3 MA70 Supra
blackmk3
Postby Malcolm » Thu Aug 04, 2005 7:40 pm
I would definitely start by completely flushing the fluid, the stuff in there is probably 15 years old and full of water. If you want really good pads talk to steve at 0800 BRAKES, they're not cheap though...
Postby blackmk3 » Thu Aug 04, 2005 10:15 pm
i have flushed the fluid and it didnt make that much of a diffrence...
Mk3 MA70 Supra
blackmk3
Postby Gadget » Fri Aug 05, 2005 10:10 am
Have a read of this:
http://forums.toyspeed.org.nz/viewtopic.php?t=32514
Some good general brake info (including fluid and rotors).
All_Fours wrote:If you want really good pads talk to steve at 0800 BRAKES, they're not cheap though...
Not cheap, but then, quality never is. Great pads (M1166 compound).
Ben.
Gadget
Postby MrOizo » Fri Aug 05, 2005 11:55 am
the brakes from a JZA80 fit... only the earlier rear ones i think...
have a search on supra foums for some better info
www.supaforums.com
chur chur
MrOizo
Toyspeed Legend
Postby Silent Knight » Fri Aug 05, 2005 12:25 pm
MrOizo wrote:the brakes from a JZA80 fit... only the earlier rear ones i think...
www.supaforums.com
chur chur
Yea but those would be the 2pots or 1pots wasn't it? For the earlier model JZA80s so won't really make that much of a difference IF they do fit.
Best thing to do is get new vented rotors and good quality pads with a full system flush and she'll do all the breaking you might need... :wink:
Silent Knight
Postby blackmk3 » Fri Aug 05, 2005 7:09 pm
chhers guys mite just have to give 0800 brakes a call and see what we can do
Nick
Mk3 MA70 Supra
blackmk3
Postby Stephen » Sun Aug 07, 2005 10:07 am
Grab a copy of the latest zoom magazine,they did a artical on upgrading to late model supra slotted discs and nissan 4pot calipars with braide lines and new fluid was on a soarer but they have the same set up as a supra.they neededspacer rings to fit the disc and a adapter plate to fit the calipars.he said it made a big difference.
Stephen
Postby blackmk3 » Mon Aug 08, 2005 7:19 pm
cheers for that ill go and get a copy! :)
Mk3 MA70 Supra
blackmk3
