ST215 Wastegate Actuator. Bent??
Postby michion » Sat Aug 06, 2005 4:23 pm
I recall seeing a post about someone with a bent wastegate actuator rod, which was suppost to be straight.
My question, is the actuator rod on a caldina GTT suppost to be straight, because mine has a few kinks in it. Is this normal on a caldina or has it been damaged?
michion
Postby crnkin » Sun Aug 07, 2005 12:12 am
It will most likely be normal, theyre bent to clear stuff. If your cars running like shit and over/under boosting or doing funny things worry bout it, if not, dont :P
deaf_homo "currrently yes"
crnkin
Postby Wildcard » Sun Aug 07, 2005 1:01 am
Its 'bent' from factory, so as above if your car performs properly do not be concerned. Also FYI if you test your actuator with ~1bar of pressure the actuator arm should move approximately 18mm.
Wildcard
Toyspeed Founder
Postby michion » Sun Aug 07, 2005 1:13 pm
Thanks guys.
I was hoping this was the case.
michion
Postby vvega » Sun Aug 07, 2005 2:41 pm
Wildcard wrote:Its 'bent' from factory, so as above if your car performs properly do not be concerned. Also FYI if you test your actuator with ~1bar of pressure the actuator arm should move approximately 18mm.
i thought it wa 25mm ??
wasent 18mm the ct26 twin wategate one
v
vvega
Postby Santa'sBoostinSleigh » Mon Aug 08, 2005 10:37 am
pics or it didnt happen!??!!!!
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby 99gtt » Mon Aug 08, 2005 7:11 pm
Santa how does what you said have any relevants in this post what so ever. Are you going to modify your car for real or just talk about all the things your going to do. You havent sorted your springs and shocks out yet and your ranting and raving about an intercooler. I think you should show some pics or it didnt happen.
99gtt
Postby Santa'sBoostinSleigh » Mon Aug 08, 2005 7:18 pm
99gtt wrote:Santa how does what you said have any relevants in this post what so ever. Are you going to modify your car for real or just talk about all the things your going to do. You havent sorted your springs and shocks out yet and your ranting and raving about an intercooler. I think you should show some pics or it didnt happen.
i was asking in relevance to see if anyone had pics to compare with mine.
well actually i do have the the springs sitting in my shed, shocks are being ordered after payday....
im pricing up intercoolers as well - i just want to make sure i go about it the right way, right size etc as im not an expert in that particular field
what would you like pics of?
i cant think of that many things i've said im going to do that i havent done really....
no need to make personal attacks here!
Santa's Mega Sale
Postby 99gtt » Mon Aug 08, 2005 7:26 pm
pics of what an actuator and show these pics as proof to the actuator exsisting.
99gtt
Postby Santa'sBoostinSleigh » Mon Aug 08, 2005 7:35 pm
i was referring to the 'bentness' described in the original posts
Santa's Mega Sale
Postby Dell'Orto » Mon Aug 08, 2005 10:00 pm
Perhaps a picture of the actuator in question is more relevant to the thread than asking his motives?
Dont you have a dyno run to do? :roll:
Postby 99gtt » Mon Aug 08, 2005 11:03 pm
wrong guy caldina gtt
99gtt
Postby michion » Mon Aug 08, 2005 11:57 pm
Cant see that a pic would clear this up. I'm not going to take the I/C off again, just to take a pic. Either its suppost to have a few kinks, or its suppost to be straight.
99GT, Mayby you could confirm that its suppost to have a few kinks in it the next time you take the top mount off?
My conclusion is that the kinks are normal though.
michion
Postby Inane » Thu Aug 18, 2005 11:14 am
ill take a look + pic just to clear it all up
Inane
Postby Santa'sBoostinSleigh » Thu Aug 18, 2005 11:23 am
i actually had my IC off at the weekend and mine has some lil bends in it, so im assuming this would be the same thing
Santa's Mega Sale
