Helping friend out here, apparently the 4agze injecotrs are low impedance??? (help here please), it's been claimed the gze ones are, Friend is going to run turbo 4age with aftermarket etc, Now i've got some 3SGE injectors lined up from an Altezza Beams 3SGE injectors, these are high impedance.
Will this affect the ecu, (being aftermarket should be right to tune it. ) as the settings are for the turbo it came with on the engine, only thing is how will the injectors affect the settings on the ecu, will we need toi run a resistor with the wiring for the injectors??? As they may be over fuelling the engine.
