by KinLoud » Sat Sep 10, 2005 8:47 am
Yes - any time I have had to fly a piston engined aircraft with a new engine just fitted. The engineer says "don't muck around on the ground too long, takeoff and use 100% power for the first 20 minutes, then 80% for the next 40 minutes"
For the first 50 hours of flying the new engine should be used on navigation flights using 75% power. After that the aircraft can do circuits and all the other lower powered flying that occurs in flight training.
Also - they use mineral oil for the first 50 hours before switching to synthetic.
Ken
Ham
021 408 863
