Disconnecting track rod end from steering knuckle arm.
Postby pervert » Sat Sep 10, 2005 2:49 pm
I'm trying to change the steering rack boot on my KE70, but I can't get the track rod end free from the steering knuckle arm.
I remove the pin, then the top nut off the track rod, but then I can't get it out of the steering knuckle arm, it's stuck solid...
I've trying levering it, and tapping it with a hammer...but no luck...what kind of tool is best to use for doing this when this happens? Any tricks?
pervert
Postby Peradx » Sat Sep 10, 2005 3:02 pm
A very big hammer and smack the sh*t out of it :lol:
Peradx
Postby pervert » Sat Sep 10, 2005 3:03 pm
Peradx wrote:A very big hammer and smack the sh*t out of it :lol:
Yea, but I don't really want to damage the bolt and not be able to get the nut back on... 8)
pervert
Postby AJz » Sat Sep 10, 2005 3:08 pm
seems the best solution to many a problem, and can be put to other uses outside car mechanics :twisted:
I had vtax :(
AJz
Postby Peradx » Sat Sep 10, 2005 3:22 pm
put the nut back on before hitting it first thou. all you want to do is crack it so its loose.
It's how we do it at work, the first time I did it, it quite a few knocks to get it.
also by leaving the nut on you wont damage the thread.
Peradx
Postby pervert » Sat Sep 10, 2005 3:25 pm
Haha, fair enough...I'll give it a try later on then...I've already tried hitting it as hard as I am game to though...when doing some research I see there is such a thing as a tie rod seperator...maybe that might be the go... 8)
pervert
Postby fivebob » Sat Sep 10, 2005 3:29 pm
There's a Toyota special tool to do this, basically it a heavy tube with a bolt in one end and a cutout with two tags at the other end which slides over the knuckle. You could make your own if you have access to a welder.
see http://www.mr2-tech.com/bgb/mechanical/ ... 5_0001.jpg for a drawing which shows the tool.
Failing that I would suggest a copper mallet instead of a hammer as it's less likely to do less damage to the thread. Make sure you support the steering knuckle so that all the force is transmitted to the rod end. A bit of heat first may help, but be careful not to overdo it or you may damage something else
Postby fivebob » Sat Sep 10, 2005 3:36 pm
pervert wrote:when doing some research I see there is such a thing as a tie rod seperator...maybe that might be the go... 8)
Also known as a pickle fork :wink:
However it not much use on Toyota tie rod ends, you'll just ruin the ball joint :evil:
Postby fivebob » Sat Sep 10, 2005 3:52 pm
Quick search and I found Powerbuilt tools make just the device you need;
see http://www.powerbuilttools.co.nz/powerb ... ension.htm look for tie rod puller (half way down the page), or possibly the tie rod end puller or Pitman arm puller might do the job, if the gap is the right size.
Postby pervert » Sat Sep 10, 2005 5:04 pm
You are the man fivebob, I might try giving it a go with a copper mallet, and I never thought to apply some heat...duh...good chance to get the old blowtorch out...thanks heaps.
pervert
Postby Ae92typeX » Sat Sep 10, 2005 8:21 pm
another thing I do is put a smaller nut on the end before I wack it with a hammer. Often the end is tapered a little, allowing for a smaller thread nut to sit firmly on the taper. Ive found in the past, the thread can still be damaged with the regular nut on- even if you turn it a bit after each hit. Since I used the smaller nut trick have never had a problem.
yea, I always try to use a copper hammer.
Ae92typeX
Postby TrouserFxGt » Sat Sep 10, 2005 8:23 pm
if there is enough room and you have two hammers then, at exactly the same time, hit the top of the bolt and the side of the housing.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby fangsport » Sat Sep 10, 2005 11:49 pm
depending on the size of your hammer, 2 hits to the steering knuckle(not tie rod end) and the joint will separate. i do this operation up to 4 times a day with no issues.
fangsport
Postby Lloyd » Sun Sep 11, 2005 9:56 am
Yup, dont go hitting the threaded bit as all you'll do it bugger it. Hit the bit its going into a few times and it should basically fall out.
Postby AE85coupe » Mon Sep 12, 2005 11:08 am
hey bro i've got a tool that looks like that powerbuilt tie-rod seperator
i've used it on my tie rods before, you can borrow it if you want
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby pervert » Mon Sep 12, 2005 12:09 pm
AE85coupe wrote:hey bro i've got a tool that looks like that powerbuilt tie-rod seperator
That would be awesome, I'm going to give it a good heat and smack tonight, and if that fails I'll send you a PM... 8)
pervert
Postby fangsport » Mon Sep 12, 2005 12:35 pm
i recommend heating it. there is every chance the grease or rubber boot on the tie rod with catch fire, furthermore, if the WOF guys see that it has been heated, they will fail a WOF.
fangsport
Postby pervert » Mon Sep 12, 2005 12:46 pm
fangsport wrote:i recommend heating it. there is every chance the grease or rubber boot on the tie rod with catch fire, furthermore, if the WOF guys see that it has been heated, they will fail a WOF.
I take it that's suppposed to be 'don't' reccommend heating it? :lol:
It's OK, I'll be careful...and if all turns bad, then I have no-one to blame but myself... 8)
pervert
Postby fangsport » Mon Sep 12, 2005 12:58 pm
no, it's a full recomendation . if you want to spend even more woney on it :wink:
just take up the offer of borrowing the proper tool.
fangsport
