4agze pully kit building question
Postby lil » Thu Oct 06, 2005 6:38 pm
I'm just in the process of increasing the diameter of my crankshaft pulley and have a couple of questions.
Does any one know what size belt I will need to use?
Also what tensioner should I use? (part numbers anyone?)
I'm planning on turning an ally ring at work then press fitting it on the the turned down existing pully. I want to make a 175mm diameter pully, it this dimension taken from the outside or inside of the V's in the pulley?
Any help would be appreciated.
lil
Postby Pelo » Thu Oct 06, 2005 7:59 pm
Can't help with the rest of the stuff sorry, but I changed my belts the other week and I used a 5PK955 belt, my car has a cusco 14psi pulley (175mm)
Pelo
Postby Rick » Thu Oct 06, 2005 8:03 pm
Talk to the man who has made heaps of these, simon, "evil_si"
Postby Bazda » Thu Oct 06, 2005 8:30 pm
pretty sure taken from the outside, when i got mine made i got it done to 180mm :D but then u have to skim the lips off the water pump pulley.
Postby IH8TEC » Thu Oct 06, 2005 8:32 pm
if you are going to the trouble of making the pulley yourself, it is PISS easy to do the tensioner, just go buy a bearing to suit, then it is pretty easy to make the pulley itself.
from my vague memory, 175 is the overall diameter, been a while since i've had it in front of me. simon maybe able to correct me if i'm wrong.
Postby evil_si » Thu Oct 06, 2005 9:10 pm
175mm is the outside of V
be careful if using alloy outer, have seen a few alloy ones that have moved, may pay to machine a locating shoulder and grub screw.
5pk 965,
you can machine a new outer for your original bearing as well, thou usually easier to go to a bearing shop.
evil_si
