Safe boost level on 91?
Postby Mr Revhead » Fri Oct 07, 2005 7:38 pm
these cars are designed to run on 100 octane in factory trim.
you work it out
Postby Malcolm » Fri Oct 07, 2005 7:46 pm
Adydas wrote:I run 91 with about . 8 bar ( area ) = 11 or 12 psi on my stock
Gt-4 how ever its not a daily driver as i have a company car and If i blew up the 20 year old motor its just motivation to seek a Higher gen motor :P :P :P
but ive done Fineeeee on it for the past 5 months no visble issues ( other than Engine Mounts )
that's because you can't see the top of the pistons 8O
seriously, i know it's tempting but you shouldn't run any japanese turbo engine on 91, unless you have an aftermarket ecu and it's tuned to run on 91.
The improvement in fuel economy will offset the cost per litre of higher octane fuel, with the added bonus of not destroying your pistons.
Postby Dell'Orto » Fri Oct 07, 2005 9:44 pm
Adydas wrote:but ive done Fineeeee on it for the past 5 months no visble issues ( other than Engine Mounts )
Have you pulled the plugs yet?
