by Malcolm » Fri Oct 07, 2005 12:01 pm
I've got a suggestion - forget about the value of the torque given by the dyno.
Torque is varied through a drivetrain every time there is an form of reduction (gearbox, diff). This means the torque measured at the wheels will be several times what it really is at the engine.
Power, however, is constant, regardless of what reductions it might go through (not accounting for drivetrain losses).
I was simply showing that math to prove how inaccurate the torque figures given by dyno's are. It represents neither torque at the wheels nor torque at the engine, although I'm sure it's supposed to show torque at the engine, it is quite clearly very wrong. And no, there's nothing wrong with my calculations.
