2ZZGE swap
Postby TRD Man » Wed Oct 19, 2005 2:00 pm
TRDWGN wrote: it is very probably the physical relocation of a 2ZZGE into a AE111/101 seems very feasible.
It certainly seems so.
Interesting that 3 of the 4 engine/gearbox mounts needed to be customised and he needed custom made axles.
It would seem that the AE111 Corolla is narrower than the Matrix but there's an engineering solution to everything.
TRD Man
Postby spencer » Wed Oct 19, 2005 4:04 pm
TRD Man wrote:
TRDWGN wrote: there's an engineering solution to everything.
amen to that! You can do it just the cost depends on how much you can fab your self.
spencer
Postby TRDWGN » Wed Oct 19, 2005 6:35 pm
Yeah interesting they say they had to swap 3 mounts, i wonder if that had something to do with it being auto in the first instance? I will try and hunt down the sites i found where the AW11 guys were transplanting C60's to their 4AGE's etc as i recall their findings were mounting points were the same for the box, just the bell housing needed t obe swapped over however it was a bolt on bolt off proposition
TRDWGN
Postby Mr Revhead » Wed Oct 19, 2005 8:23 pm
c60? or c160?
Postby TRDWGN » Wed Oct 19, 2005 8:33 pm
Mr Revhead wrote:c60? or c160?
C60 out of the celica's
TRDWGN
Postby Alex B » Wed Oct 19, 2005 9:20 pm
also in corolla RunX
Postby Mr Revhead » Wed Oct 19, 2005 9:40 pm
ok, wonder why they dont use the c160...
Postby TRDWGN » Wed Oct 19, 2005 9:59 pm
Mr Revhead wrote:ok, wonder why they dont use the c160...
More plentiful in supply is all i can guess :lol: (well in their market)
TRDWGN
Postby Mr Revhead » Wed Oct 19, 2005 10:07 pm
must be. c160 bolts up
