by paul123 » Mon Nov 14, 2005 7:21 pm
When you put the head on your 3a you will find the valves will hit the pistons by quite alot so i had to cut the grooves in the top of them to stop them hitting,they look just like standard 4age piston's.Would of been easier to put 4age pistons in,Your's being a 3a will have a smaller bore so you can't do that.
At the end of the day once you pay for all the machine work it would be cheaper to buy a 4age.
I only did because i did all the work myself and if it self destructed the motor cost me nothing.
