What are these called?
Postby Volatile » Fri Dec 16, 2005 8:10 pm
In the engine bay of an ae82 corolla, where the steering components come thru the firewall and split off to the left and right going towards each wheel
here's a pic
Volatile
Postby Low_Aa63 » Fri Dec 16, 2005 8:21 pm
steering rack boots or streering arm boots...something like that
The list so far
Te71, Ae82, Ke70x2, Mx73x2, Ga61, Gx61, Ra63, Aa63, Ae70, Ae85, Ke25, Ke30, Ke36, Gz10x2, Hb11, Ta40, Ma45......
Low_Aa63
Postby RedMist » Fri Dec 16, 2005 8:46 pm
If its the rods you are talking about, then its called a tie rod or steeing rod.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Lloyd » Fri Dec 16, 2005 9:28 pm
1 is steering rack boot, 2 is the rack, inside on each end will be the rack ends, and the bits between there and the wheels is the tie rod end
Postby Volatile » Sat Dec 17, 2005 6:04 pm
HRT wrote:1 is steering rack boot, 2 is the rack, inside on each end will be the rack ends, and the bits between there and the wheels is the tie rod end
Thanks, Ive got a clunking sound comming from this area. When i grab the bar on the passenger side ( which is further to the right of number 2) it can lift it slightly up and down making the knocking sound.
My question is how do i work out what i need to replace?
Volatile
