Should i go box?
Should i go box?
Postby The_Sorrow » Tue Dec 20, 2005 9:28 pm
Ok, lets try this again
I am in the middle of making this for my 92 Levin Gt-apex
http://www.4age.net/tech/coldair.htm
My question is should I
a) Continue to do this. Its a good idea, done properly
or
b) Forget it, pipe from the factory airbox to the front bumper and get a better panel filter
Which one would give the best result?
And yes, I have used the almighty search button
chur-chur
Just another sh*thead wanker apprentice :P
The_Sorrow
Re: Should i go box?
Postby barryogen » Wed Dec 21, 2005 8:35 am
The_Sorrow wrote:Ok, lets try this again
or
Has anyone done something similiar?
Or have something better to recommend?
until I see a dyno plot of a pod making a difference, I say just pipe cold air to your existing box.
And yes I realise my car has a pod, it had it when I bought it, so I added a CAB to atleast grab colder air.
barryogen
2ZZ Guru in training
Postby Lanius » Wed Dec 21, 2005 11:56 am
Great, now that we know you've already tried searching ... ditto to Mr Rev's reply :wink:
FWIW, you might also want to investigate trumpets for your intake ... its an option for a 20 valve motor that can produce good results if done correctly (read: with very good cold air supply).
Lanius
Postby Mr Revhead » Wed Dec 21, 2005 12:40 pm
dyno is the only way to tell
a pod on one car may lose power, but gain on another.....
Postby The_Sorrow » Wed Dec 21, 2005 7:30 pm
Lanius wrote:
The_Sorrow wrote:And first person to say search it, been done before blah blah........ :evil:
First person to say it ... what? You'll growl at them over the internet?
At least make an effort, or mention that you've made the effort, before expecting everyone else to do your research for you :roll:
Yes, dozens and dozens of the members of this forum have done this before, and surprise surprise, they've posted about it. That automagical search button at the top of the screen will show you their posts. Why are you special that you don't have to search like everyone else?
viewtopic.php?t=40528&highlight=cold+air
viewtopic.php?t=40020&highlight=cold+air+box
viewtopic.php?t=39736&highlight=cold+air+box
viewtopic.php?t=38839&highlight=cold+air+box
viewtopic.php?t=38467&highlight=cold+air+box
viewtopic.php?t=37130&highlight=cold+air+box
viewtopic.php?t=38491&highlight=cold+air+box
viewtopic.php?t=38416&highlight=cold+air+box
viewtopic.php?t=37028&highlight=cold+air+box
viewtopic.php?t=35103&highlight=cold+air+box
viewtopic.php?t=30169&highlight=cold+air+box
Apologys, I have made full use of the almighty search function and have scrolled through every topic you have just listed and more. The problem is that none answer the question I have asked which is, of these two options, is one better than the other. Should have added that.
And no, I don't expect people to do research for me. That is what I am doing now by asking experts.
But thanx, Mr Revhead and barryogen, that was the answer I was looking for
The_Sorrow
Postby Lanius » Wed Dec 21, 2005 8:06 pm
Lanius wrote:Great, now that we know you've already tried searching ... ditto to Mr Rev's reply :wink:
Lanius
Postby The_Sorrow » Wed Dec 21, 2005 8:17 pm
Well, thanks for that dude
Correct me if I am wrong but aren't trumpets really designed for a MAP sensored engine, and wouldn't work with an AFM, which mine is?
The_Sorrow
Postby Mr Revhead » Wed Dec 21, 2005 10:51 pm
silvertops are AFM
Postby Lanius » Wed Dec 21, 2005 11:11 pm
The_Sorrow wrote:Well, thanks for that dude
Yup, but theres ways and means around this :)
Depends on your budget etc really, but good point, I forgot about that.
Lanius
Postby The_Sorrow » Thu Dec 22, 2005 8:30 am
Yea, I think I might as well just move the battery to the boot and make a proper CAB instead of pissing round with this half-assed sh*t I was thinking of doing.
Unless someone has a better idea that they could be bothered explaining to me. I could search but I'm real stoooopid when it comes to these sorts of things
Thanx anyway dude
The_Sorrow
