by vvega » Thu Jun 23, 2005 2:02 am
How can I test my O2 sensor?
They can be tested both in the car and out. If you have a high
impedence volt meter, the procedure is fairly simple. It will
help you to have some background on the way the sensor does
it's job. Read how does an O2 sensor work first.
Testing O2 sensors that are installed
The engine must first be fully warm. If you have a defective
thermostat, this test may not be possible due to a minimum
temperature required for closed loop operation. Attach the
positive lead of a high impedence DC voltmeter to the Oxygen
sensor output wire. This wire should remain attached to the
computer. You will have to back probe the connection or use
a jumper wire to get access. The negative lead should be
attached to a good clean ground on the engine block or
accessory bracket. Cheap voltmeters will not give accurate
results because they load down the circuit and absorb the
voltage that they are attempting to measure. A acceptable
value is 1,000,000 ohms/volt or more on the DC voltage.
Most (if not all) digital voltmeters meet this need. Few
(if any) non-powered analog (needle style) voltmeters do.
Check the specs for your meter to find out. Set your meter
to look for 1 volt DC. Many late model cars use a heated
O2 sensor. These have either two or three wires instead of
one. Heated sensors will have 12 volts on one lead, ground
on the other, and the sensor signal on the third. If you have
two or three wires, use a 15 or higher volt scale on the meter
until you know which is the sensor output wire.
When you turn the key on, do not start the engine. You should
see a change in voltage on the meter in most late model cars. If
not, check your connections. Next, check your leads to make sure
you won't wrap up any wires in the belts, etc. then start the
engine. You should run the engine above 2000 rpm for two
minutes to warm the O2 sensor and try to get into closed loop.
Closed loop operation is indicated by the sensor showing several
cross counts per second. It may help to rev the engine between
idle and about 3000 rpm several times. The computer recognizes
the sensor as hot and active once there are several cross counts.
You are looking for voltage to go above and below 0.45 volts.
If you see less than 0.2 and more than 0.7 volts and the value
changes rapidly, you are through, your sensor is good. If not,
is it steady high (> 0.45) near 0.45 or steady low.
Testing O2 sensors on the workbench.
Use a high impedence DC voltmeter as above. Clamp the sensor in
a vice, or use a plier or vice-grip to hold it. Clamp your
negative voltmeter lead to the case, and the positive to the
output wire. Use a propane torch set to high and the inner blue
flame tip to heat the fluted or perforated area of the sensor.
You should see a DC voltage of at least 0.6 within 20 seconds.
If not, most likely cause is open circuit internally or lead
fouling. If OK so far, remove from flame. You should see a
drop to under 0.1 volt within 4 seconds. If not likely silicone
fouled. If still OK, heat for two full minutes and watch for
drops in voltage. Sometimes, the internal connections will open
up under heat. This is the same a loose wire and is a failure.
If the sensor is OK at this point, and will switch from high to
low quickly as you move the flame, the sensor is good. Bear in
mind that good or bad is relative, with port fuel injection
needing faster information than carbureted systems.
ANY O2 sensor that will generate 0.9 volts or more when heated,
show 0.1 volts or less within one second of flame removal, AND
pass the two minute heat test is good regardless of age. When
replacing a sensor, don't miss the opportunity to use the test
above on the replacement. This will calibrate your evaluation
skills and save you money in the future. There is almost always
*no* benefit in replacing an oxygen sensor that will pass the
test in the first line of this paragraph.
