Wheel Alignment
Wheel Alignment
Postby supraman_nz » Tue Jan 03, 2006 4:56 pm
Hi
My steering wheel in the Camry (99) has been shaking pretty bad recently ,
Just checking if all thats needed is for an alignment ?
I dont want to go wasting $70 on one if its not casuing the problem.
Iv tryed pumping up the tyres and that wasnt the cause.
Thanks in advance
supraman_nz
Postby rallymazda » Tue Jan 03, 2006 5:10 pm
more likely wheels need balancing
[4AGE8U] << my old number plate
Got me a new altezza, now arrived
1991 corolla wagon- work hack
rallymazda
Re: Wheel Alignment
Postby BZG Wagon » Tue Jan 03, 2006 5:34 pm
supraman_nz wrote:Hi
Thanks in advance
Steering Wheel Shakes = Font Wheels need Balancing
Chassis Shake = Rear Wheels need Balancing
Car pulls to the left or right, uneven tyre wear, poor cornering = Wheel Alignment.
BZG Wagon
Postby supraman_nz » Tue Jan 03, 2006 6:50 pm
oh i see , so a wheel balancing not alignemnt.
Is that around the same sorta price ?( i know it will vary from place to place but just a rough idea)
supraman_nz
Postby BZG Wagon » Tue Jan 03, 2006 8:53 pm
A balance is about $10 per wheel. An Alignment is between $26 and $70 for all 4 wheels.
If you have old mags, they could also be slightly buckled (which is very common, and nothing to worry about). If this is the case, a balance should minimise any vibration but it might not get rid of of the vibration completely.
If its a 99 camry, I wouldnt expect this to be the case, unless the wife has hit something at speed (also could be very common) :D .
If it only vibrates when you are breaking, you could also have a warped disc rotor, which would just require the discs to be machined (not a biggie either).
BZG Wagon
Postby supraman_nz » Tue Jan 03, 2006 11:05 pm
Cheers BZG wagon,
i will go and get it sorted tomorrow
thanks for your help
supraman_nz
