Stealer Of Souls wrote:
I didn't know that there was and adjustment for cooling temp... What do I do?
Remove the glove box.
On the side of the a/c core is a square box. it may have a/c amplifier on it, and will have a multi pin plug in the top.
From memory it unbolts and you can hang it on the wires.
It will also have a adjuster in the top with rpm on it.
That adjusts thye low speed cut out so leave it where it is.
If you unplug it and carefully remove the circuit board it will have another adjuster hidden inside the box, that adjust the temp.
Plug the board back in out of the case and make sure it doen not short out on anything.
start and run the car and adjust the temp.
then re-assemble.
this is as long as everyting in the actual a/c system works.
Also try the a/c when the car is dead cold and see if it cools enough as somtimes the a/c works but the heater tap leaks and heats it back up again.
Matt
