Funny noise on Idle
Postby ollieboy » Sat Feb 18, 2006 12:23 am
Sorry to bring this topic up again but It still makes a tapping sound. But I have narrowed it down to near the intake manifold and it sounds like maybe an injector or two is causing the sound. And when I touch the electrical plugs that I think are near or control the injectors I can feel a tapping in time with the noise so I believe this may be the problem.
Also, anyone know how to get sparkplugs out of a 5afe :oops: They are really deep in and I'm not sure whether to use an extension bit or not. I am going to replace the plugs. Whats a good brand? Just the normal sparkplugs from the garage be ok? Do you need to adjust the sparkplug for best spark like you used to or is it already done for you now?
Sorry about all the questions but I am wanting to get my car running beautifully so I am reaplacing all the shiz that needs replacing.
ollieboy
Postby Ae92typeX » Sun Feb 19, 2006 10:34 am
injectors can get noisy, so its a possibility.
For plugs, you use a extension on your plug socket- the majority of twin cams require that now. if they have never been out, maybe give a spray of crc the night before, as any water which has run down there ever will have coroded them a little, making harder to remove.
just get some standard plugs- champion or whatever- if you look up in the book it will tell you the electrode gap, but 90% of the time for a engine like yours, they will be pre gaped and just require fitting.
while you are there, if you have a multimeter, test all the ignitions leads also to see if any are out of reccomended spec.
Ae92typeX
Postby ollieboy » Sun Feb 19, 2006 3:26 pm
So would it be pretty easy to replace or clean the injectors to stop them tapping?
Thanks for your help man
ollieboy
Postby Ae92typeX » Sun Feb 19, 2006 4:36 pm
Put a seperate post up about getting injectors cleaned if you cant find anything in search- I remember someone talking about getting theirs done a while ago...cant recall who- one of the regulars.
not something you can do yourself though (cleaning them that is). Also, depending on price to get done, it may be cheeper to try afew from pick a part or similar (correct ones of corse).
If you do the injectors remember to replace the o-rings- they are not meant to be reused and its not worth risking it since you would have to dissasemble it all if you do get a leak.
Ae92typeX
Postby ollieboy » Mon Feb 20, 2006 12:51 am
Cool thanks. Oh and I remember reading somewhere you had access to a 5afe. Would you be able to tell me the resistance of the leads. :D
Cheers man
and I searched for injector cleaning, found out its a lot cheaper then I imagined so I gotta have a ring round tomorrow.
ollieboy
Postby Ae92typeX » Mon Feb 20, 2006 8:17 am
off to work in my shirt n tie, so best I dont get under the car at the begining of the day, but
as an indication, max resistance between dizzy cap terminals (cap off) and sparkplug wire ~25,000 ohm (from 4age manual)
there is a more mathmatical equation which works on the length of each, but it escapes me. We used to change them at anything over ~15,000 in the shop when I was there.
Ae92typeX
Postby ollieboy » Wed Feb 22, 2006 5:33 pm
:oops:
I tried to test the leads but the multimeter said there was no current, is there a special way of testing them?
EDIT: I meant, it should just work if I stick the probe bits on each end touching metal yeah?
ollieboy
Postby Ae92typeX » Wed Feb 22, 2006 5:56 pm
yea, take them off engine one at a time, make sure the prongs are touching- especially make sure on the plug side, as it can be harder to hold in position depending on prong type.
make sure mulitmeter is set to ohms & correct scale (what scale of ohm choice do you have on yours?).
you should get something. If you get nothing, touch the prongs together to make sure they are working.assuming they are, you would have a broken lead.
Ae92typeX
Postby ollieboy » Wed Feb 22, 2006 9:00 pm
Finally got it working just before, don't know what happened the first time.
These are the readings I got.
1- 10.4 at 200K setting on multimeter
2- 9.6 @ 200K
3- 7.8 @ 200K
4- 6.8 @ 200K
Do these sound alright?
ollieboy
Postby ollieboy » Wed Feb 22, 2006 10:01 pm
Also, when I get the injectors cleaned should I replace the fuel filter as well?
ollieboy
Postby Ae92typeX » Thu Feb 23, 2006 8:08 am
Sound fine
May as well do the fuel filter, espeically if you never have before
Ae92typeX
Users browsing this forum: Bing [Bot] and 12 guests
