buying a 4agze
buying a 4agze
Postby bluemaumau » Tue Feb 28, 2006 10:17 pm
hey im looking at a ae92 gtz complete.
i only want the fuel system driveline and engine ecu etc.
so wat should i look for? any tips?
here are some numbers i got from the firewall.
ae92 5027135
e-ae92-bcmxr
is this a good versuion?
its afm and has got a lsd
Postby Adydas » Tue Feb 28, 2006 10:29 pm
i deem it somewhat more of a technical question, so better suited here.
Adydas
Postby bluemaumau » Tue Feb 28, 2006 10:30 pm
swt. wasnt too sure.
can anyone help?
Postby Caveman » Tue Feb 28, 2006 10:42 pm
Make sure you buy a running one.
AFM is ok. AFM and MAP both have limitations, i'd say the AFM would be more accurate at measuring the air than MAP.
LSD is a bonus, but could be screwed. It should be a clutch type LSD.
If you get the E series box make sure you get the hubs and axles too.
Fuel pumps are average. I wouldnt want to flow more than 200HP with it. Since it rated to 120L/h which is around 200HP
Just listen for piston slap, rattly bottom end, heavy breathing, all the usual things.
Caveman
Postby bluemaumau » Tue Feb 28, 2006 10:46 pm
yea i took it for a drive. was pretty nice.
a clutch type lsd? wtf is that?
wat other types can you get?
is the one im lookin at e series?
would gtapex ae101 hubs and shafts be sweet?
its just gona stay sc for a while. i just want the pump cuz i dunno if the 4afes up to the task lol :lol:
Postby Caveman » Tue Feb 28, 2006 10:57 pm
Im not 100% sure if there clutch type. Its hard to tell exactly whats on toyota gearboxs.
The other common toyota LSD is viscous type which imo isn't as good.
To be sure you would have to get the axle code on the build plate.
ae101 shafts and hubs will not work with an e series box. If you get the e series gearbox get the shafts and hubs too. e series box is stronger, used with the mr2 turbo.
Caveman
Postby bluemaumau » Tue Feb 28, 2006 11:00 pm
how do i find out if its an e series box??????????????? 8O
Postby Caveman » Tue Feb 28, 2006 11:03 pm
1998 wrote:To be sure you would have to get the axle code on the build plate.
If it came with a 4agze, and the registration is 'gt-z' then you can be pretty sure its a e series box
Caveman
Postby bluemaumau » Tue Feb 28, 2006 11:06 pm
fuk. so i just bought a ae101 wreck for the 4 wheel disk brakes and i can t use them ! lol.
dammit cuz this things front left hub is $&#$%.
Postby bluemaumau » Wed Mar 01, 2006 7:12 am
is this model the good one ?
oil squiters etc?
Postby bluemaumau » Wed Mar 01, 2006 3:22 pm
anybody wana help me? :roll:
Postby EVLGTZ » Wed Mar 01, 2006 4:16 pm
pretty sure ae92 ze does not have oil squirters
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby IH8TEC » Wed Mar 01, 2006 4:26 pm
EVLGTZ wrote:pretty sure ae92 ze does not have oil squirters
correct, only the map sensored ones do, so possibly still a ae92 one, jsut the really late ones that were mapped
Postby bluemaumau » Wed Mar 01, 2006 4:44 pm
ok well this is afm.
still a gud engine? :?:
Postby IH8TEC » Wed Mar 01, 2006 4:45 pm
bluemaumau wrote:ok well this is afm.
thats what i got 8) yeah it's still a very good strong engine. :twisted:
