Jebus wrote:A worn LSD has the effect of an open diff.
okay, cheers, guess my friends car is just buggered, we thought it might be tyres at first but changed them all twice so I guess it must be buggered.
Dragger_Dan wrote:In theory the clutches should start to wear out on an ageing LSD, therefore having quite the opposite effect
l1ttle_d3vil wrote:Dragger_Dan wrote:In theory the clutches should start to wear out on an ageing LSD, therefore having quite the opposite effect
when this starts happening is there anything you can do to fix it, other than buying a new clutch pack which is worth more than the diff head itself?can't you pack some shims behind the clutch plates or something so they grip some more? im not familiar with the internals of LSD's at all but this is what I've heard you can do to some of them.
