BZR Driveshaft compatibility....
Postby bad20v » Tue Mar 21, 2006 11:31 am
What I thought was a CV joint failure in my 1997 Trueno BZR, is upon inspection a broken driveshaft.
What I need to know is if these driveshafts are the same as any other models, i.e: BZG, Corolla etc?
Its for the right-hand side.
Does anyone have a suitable replacement for this broken shaft available?
Thank-You.
bad20v
Postby sergei » Tue Mar 21, 2006 3:37 pm
Shafts should be the same as any manual 20V (I'm running AE101 shafts with C160)...
Postby AceSniper » Tue Mar 21, 2006 8:37 pm
shafts are the same as pritty much any 4age fwd, 4afe is the same on the short side but they dont have the hanger bearing onto the block
AceSniper
Postby Mr Revhead » Tue Mar 21, 2006 11:09 pm
did u ring me at work today??
i got a call with the same question!
