the passenger side isnt working,
where do i start
Mr.Phreak wrote:Because you forgot to plug it back in when you put your trims back on??
sergei wrote:Check how easy is to lock it manually, then listen when you activate the central locking if you could hear the motor trying to lock/unlock that door, it could be electrical (power not getting to motor) or mechanical (jammed motor), pull apart door trim locate plug for that motor (should be in bottom of the door corner) measure the voltage between the pins on the plug (with motor connected, than with it disconnected), if you are getting voltage with motor connected it means that motor is jammed, either replace it or repair the jam, if you are not getting the voltage on the plug with motor disconnected, remember the colours of the wires and trace back to Door Control Unit and see if the wires intact (test resistance), the door control unit is located behind pasanger glove box (orange or black box, it says on the side of it "Door Control Unit", you could hear relays clicking inside of it when central locking activated).
