MrOizo wrote:cheers guys,,,
well it came out alright. just couldn't put the hard line in the 'newer' hose. maybe get new hoses and then have a go you reckon?
could get a flaring kit and have a go at re-flaring the hardline also.
thanks for that... will have to look into it!
in the cases i have seen, it was the actual threaded fitting(not the tubing) that had become flared due to over tightening, one case resulted in a replacement T-piece and rigid lines. if you can get it separated, you might be able to slide it away from the tubing flare and file the ridge off it.
