Torque settings 20v 4age, TRD metal headgasket.
Postby Grrrrrrr! » Tue May 09, 2006 1:00 pm
When fitting a TRD 0.8mm metal headgasket do the standard head bolt toque settings of 22ft-lbs +90d +90d still apply?
If not what is the correct setting?
Grrrrrrr!
Postby Mr Revhead » Tue May 09, 2006 1:01 pm
yes stock settings are used
Postby Grrrrrrr! » Tue May 09, 2006 9:44 pm
Can you double check that for me please Warwick..
The spec on the following page translates (according to babelfish) to 700 +/-40kgf.cm = 50ft-lbs.
http://www.trdparts.jp/english/parts_engine-4a-g20.html
Grrrrrrr!
Postby Mr Revhead » Tue May 09, 2006 10:59 pm
i wonder what the 90 + 90 works out to be over all?
when using stock bolts id go with the manual settings
if using ARP then the TRD settings (though i suspect they are the same)
of course youd still do it in 2-3 stages.....
Postby sergei » Tue May 09, 2006 11:24 pm
90+90 will work out a hell of a lot, at least it feels like it when getting to bolt #10...probably arround 100+ Nm...
