Car not starting
Car not starting
Postby malc » Tue May 16, 2006 10:39 pm
hey guys
car is an ae92 trueno
having problems starting it, not a battery problem as the engine turns over fine and sparks fine.
Seems to be a problem getting power to the fuel pump, tried bridging power from the battery to the fuel pump in the diagnosis plug, this worked for a while getting it started but now car doesnt start at all.
Possibly a fuel pump relay problem? any ideas where the fp relay is located?
or any other ideas as to what the problem is?
malc
Postby kingcorolla » Tue May 16, 2006 10:59 pm
check for power at the pump on cranking and check voltage drop
check for fuel behind the filter while cranking
fuel pump relay should be in the engine bay
is it a 4age?
1983 Carina AA63 4age
kingcorolla
Postby malc » Wed May 17, 2006 12:04 am
yea, it is a 4age 16v
cant hear the pump going when ignition is on/turning key
malc
Postby gepsk8 » Wed May 17, 2006 12:55 am
under the stero area normal for fuel pump relay
gepsk8
Postby MrOizo » Wed May 17, 2006 9:12 am
not the fuel pump itself is it? not time for a new one?
MrOizo
Toyspeed Legend
Postby malc » Wed May 17, 2006 6:10 pm
cheers guys
yeah, have found the relay now, just in front of the ecu
could be the fuel pump, will do some checks on the relay first to see if thats the problem
8)
malc
Postby kingcorolla » Wed May 17, 2006 7:20 pm
na just check for power at the pump. If theres power is there ground?
have you checked your fuses?
kingcorolla
