As above, i've received mixed advice on the whether they can be re-used or not.
And if they can, what prep is required apart from head and block being flatter than flatand clean enough to eat off?
With the TRD head Gaskets they are NOT reuseable &
upon talking to one of our Lexus Mechanics it pays to have
a definite Mirror finish on the Head & Block before fitting and running
the Engine without Coolant for 1.5 - 2 mins for a better Seal
from the Head Gasket to the Head,then letting the engine cool
again before adding coolant.
P.S Also if you are using Studs not bolts it will pay to Re Torque
the Head after around 1000kms.
Grrrrrrr! wrote:Official reply from Toyota/TRD (Well Giltrap Toyota anyways)
Interesting about the running the engine without coolant for a few minutes.
