ae85 struts + ae86 brakes = ?
Postby l1ttle_d3vil » Fri May 19, 2006 6:01 pm
Ive got some ae85 struts, what would be the best thing to do to if I were to upgrade the brakes?
1. will ae86 brakes bolt straight on?
2. will just bolting vented ae86 disks on upgrade the brakes?
3. would I also need to use ae86 calipers etc to notice a major different?
4. could I just use ae86 calipers on ae85 disks and the brakes be better?
cheers.
-matt
Postby AE85coupe » Fri May 19, 2006 7:43 pm
ae86 brakes will bolt right on, but you need the caliper, the disc and the backing plate to make it work, sometimes easier just to find complete ae86 struts
AE85 Trueno *For sale*
Details of car here
AE85coupe
Re: ae85 struts + ae86 brakes = ?
Postby NA Drifter » Sat May 20, 2006 5:58 pm
l1ttle_d3vil wrote:Ive got some ae85 struts, what would be the best thing to do to if I were to upgrade the brakes?
cheers.
-matt
1. Yes
2. No, caliper is different.
3&4 Don't think so and also if it using the std solid disk, there is no point to change the calipers
You basicly need the ae86 vented disks, calipers and possibly the back bracket? If case you didn't know, the TE71 and AE85 have the same front brakes. Never had issue with TE71 brake normaly. You only get no brakes after about 3 laps of grip racing at track. :P I was using Metal King pads.
Keith
NA Drifter
Users browsing this forum: Google [Bot] and 38 guests
