gammy BOV
gammy BOV
Postby trdfxgt » Mon May 22, 2006 12:30 pm
hi i have a hks bov and it has 2 pressure hose lines can some one through some light on this it has one in the top and one larger one on the side may just be gammy operator but the valves iv used in the past have had only one pressure line ??????
trdfxgt
Postby trdfxgt » Tue May 23, 2006 9:39 am
bump
trdfxgt
Postby aesc » Tue May 23, 2006 10:01 am
Its not a plumb-back type is it?
EX AE101 owner
2013 Ford Focus ST
aesc
Postby trdfxgt » Tue May 23, 2006 10:12 am
na its not its normal apart from have 2 lines in i have not seen one like this before
trdfxgt
Postby trdfxgt » Thu May 25, 2006 11:46 am
can anyone help ??
trdfxgt
Postby TWSTD » Thu May 25, 2006 2:57 pm
post a pic. You sure its HKS? not a greddy (or copy) diaphram BOV?
@@@ Online store NOW OPEN! @@@
Click here!
DPR | HTS | SARD | WALBRO | GARRETT | SPEC | EXEDY | MINTEX | HKS | APEXi | MAPECU | SIMOTA + more!
TWSTD
Postby trdfxgt » Thu May 25, 2006 4:52 pm
its hks for sure ill get a pic tonight
trdfxgt
Postby trdfxgt » Thu May 25, 2006 10:09 pm
here it is any ideas
trdfxgt
Postby TWSTD » Fri May 26, 2006 8:39 am
That looks like an old sequential. I didnt realise they has 2 vac ports on them?
Just like an external wastegate, one port goes to intake manifold and the other direct to pressure source from turbo.
Click here!
TWSTD
Postby trdfxgt » Fri May 26, 2006 9:46 am
by any chance you dont know which is which ????
trdfxgt
Postby sergei » Fri May 26, 2006 10:11 am
I would assume the port on top (back) of it would go to manifold, while the one on the side to turbo...
