by Quint » Sat Jun 03, 2006 12:34 pm
Had the same problem with my conversion (GA-70 tho).
As been said, auto and manual X-members are slightly differant, wat i did was machined out two pieces of plate steel, about 8mm thick painted them black, popped them in.
The new points are only ~10mm away from the vulcrom so theres hardly any leverage, so its plenty strong enough (probably stronger than the orginal), i've gone through warrants fine and 5,000+km later shes still humming away speaks for its effectiveness.
