let alone working it out
think ill just email you what i want to know and threaten you with higher prices to get what i want
AE85coupe wrote:CAMB01 wrote:45 thou or 45 thousandths of an inch is just over 1mm.
dam.. guess i've got enough compression then heh
pc wrote:Ummm.... no you can't do that.
you still need to know the volume of the
combustion chamber
+ headgasket
+ piston dip thingie
+ gap around the top of the piston
To be able to add all of these things up, you will need to know what they are.
Mr Revhead wrote:just make a spread sheet and post it up
JT wrote:Mr Revhead wrote:just make a spread sheet and post it up
I'm working on it...
Sergei, to not confuse matters () best to refer to your 'bore volume' as 'swept volume'
Truenotch wrote:AE85coupe wrote:CAMB01 wrote:45 thou or 45 thousandths of an inch is just over 1mm.
How does your smallport go with that much compression? I'm thinking about raising mine a bit.
sergei wrote:pc wrote:Ummm.... no you can't do that.
combustion chamber
+ headgasket
I disagree with you. You don't need to know this. What you need to know is the change in that "static volume", wich is pretty easy - volume of new gasket minus volume of old gasket. That will give you a change. Treat rest of the volumes as one volume "x", because it is static it will not matter what it is composed of. ie Comubstion chamber stays the same, deck heigh stays the same, piston hight/depth stays the same, what only differs is the gasket thickness. So just add/subtract (depends if thicker or thinner) the difference of new gasket volume vs old to that X.
as in here:
old C.R. = ( Bore volume + X ) / X
new C.R = ( Bore volume + X + change in gasket thickness ) / ( X + change in gasket thickness )
knowing old C.R. and Bore volume, it is possible to find X - which is combined volume of comubstion chamber, deck heigh, piston dish/dome, stock gasket. etc. Then knowing X it is possible to reintroduce it in new C.R. equation and calculate new C.R.
Simple algebra.
pc wrote:Ahhh... I see. You are assuming that the current CR is known (accurately)... I am assuming that it isn't.
AE85coupe wrote:hmm so when i took 45 thou off the head of my smallport how much did i raise the compression?
whats 45 thou in mm?
TRD Man wrote:I think you're pretty close JT. At some point we did the calculations and determined that the 0.8mm gasket raised the ratio by about 0.3 roughly.
