4agze wont rev over 2500?
Postby XSVWGN » Tue Jul 18, 2006 12:58 am
matt dunn wrote:
XSVWGN wrote:i havent got the relay on for the supercharger wired up yet
Um, so why the hell are you treying to get it to go?
If the supercharger wont work, and the ABV shuts off when the supercharger is meant to come on,
How the hell is the engine going to get any air????
I used to have the car running fine when the relay wasnt plugged up. It just runs like a normal 16valve. The car has been sitting around for a year now so it would suprise me if the pump etc is clogged up. And no i have not replaced the bolt with a solid one:P
2008 Kia rio - work car
XSVWGN
Postby flygt4 » Tue Jul 18, 2006 6:45 pm
put on truck , take to sparky , and PAY to have fixed.
flygt4
Postby XSVWGN » Tue Jul 18, 2006 9:39 pm
flygt4 wrote:put on truck , take to sparky , and PAY to have fixed.
Yea well im trying to get it going first...hoping its not eletrical as i know thats going to cost me alot of money.
XSVWGN
Postby postfach » Tue Jul 18, 2006 10:02 pm
yeah random problems can be a bitch to diagnose, i spent a solid month going over wiring diagrams and thinking i was stupid because i coudln't see what the problem with the wiring was (all signs pointed to something weird in the wiring). turned out the fuel pump in the car was somehow overpowering the stock fuel pressure reg (figured this out after replacing almost every sensor in the car)
postfach
Postby XSVWGN » Wed Jul 19, 2006 3:44 pm
yea i have replaced alot in the car and its starting to anoy me as i have spent over 1500 in parts and labour on getting it to go etc!!! i could have nearly turboed it by now!!!
XSVWGN
Postby XSVWGN » Wed Jul 19, 2006 8:45 pm
Well your right...it is eletrical. Fuel injectors cut out at 2500 rpm and now need to check fault codes but i have no dash lights :cry:
Will have to track down a 4agze ecu map to track down the wires
Matt
XSVWGN
Postby matt dunn » Thu Jul 20, 2006 12:32 am
XSVWGN wrote:Well your right...it is eletrical. Fuel injectors cut out at 2500 rpm Matt
Another guess with those symptoms would be incorrectly or non functioning TPS.
Try unplugging it and see what happens.
Postby XSVWGN » Thu Jul 20, 2006 12:59 am
TPS is all good. I had a mate come around and put his on and there was no difference. Will be off to a sparky this week and shal go from there
XSVWGN
Postby Mr Revhead » Thu Jul 20, 2006 9:58 am
Postby matt dunn » Thu Jul 20, 2006 9:11 pm
Meant to say incorrectly wired, but if the car has been running with that loom before then it should be ok.
Matt
Postby XSVWGN » Fri Jul 21, 2006 1:09 am
the ZE has been in the car for 3years and i have owned it for 18months. It was all running ages ago and then the charger stuffed out and i took it off the road and now its just one thing after another. The injectors are cutting out at 2700 now but still dont know why that is happening. Will have to check up fault codes and see whats going on.
Went on Google just before and couldnt find anything about what fault code represents what...can anyone help with that?
Matt
XSVWGN
Postby Mr Revhead » Fri Jul 21, 2006 9:42 am
theres a heap of info on the net!!
even in our FAQ section
Users browsing this forum: Bing [Bot] and 23 guests
