Extractors for 20v silvertop
Postby quicklvn » Mon Jul 10, 2006 12:40 pm
Im thinking of putting some custom extractors on my 20v Silvertop. I have a 2 1/4" exhaust to bolt them up to.
I was just wondering what is the maximum sized pipe I could use for the extractors as it is going to be a 4 to 1 set up. I've heard there are certain 'rules' as to the size of the pipe you can use for the extractors based on the size of your exhaust pipe.
Any help will be good.
quicklvn
Postby Lanius » Mon Jul 10, 2006 1:14 pm
Waste of money imo. The factory 20 valve extractors are pretty damn good, and you'd have to spend a fair bit of money to get anything better in there. Even then, you'll find minimal gain for the cost involved. There are other places you could spend the money for more gain (put your car on a diet, tyres, suspension, brakes etc).
Of course, if you've already modified everything else on the car, and extractors are the only remaining piece to be upgraded, then go for gold :wink:
Lanius
Postby quicklvn » Mon Jul 10, 2006 1:24 pm
The extractors are going to be made by a friend who is an engineer and has just done some for his 400ci V8 :) , I was also thinking of getting a blacktop head to replace my silver top. Is there any mods to be made with that? cost involved and power gains?
quicklvn
Postby Stealer Of Souls » Mon Jul 10, 2006 1:42 pm
Considered make a dual length system?
Complex. But has some very distinct advantages...
Plenty of modern cars are starting to use them...
'86 AE85.5 Levin
Stealer Of Souls
Postby Lanius » Mon Jul 10, 2006 1:44 pm
Would be cheaper / easier to just buy a blacktop and install it.
Fair enough to get your friend to make the extractors, at least you'll get them for a good price. Just make sure to keep a hold of your factory extractors in case you're not happy with the new ones :wink:
Don't forget that 4-1 extractors tend to encourage torque at the top end of your revs, while 4-2-1's are aimed more at the bottom to mid range revs. The result will be a bit more pull when you ring it out pulling onto onramps, or dropping into third on the motorway, but less when driving around town or in traffic.
Lanius
Postby KinLoud » Mon Jul 10, 2006 3:38 pm
4 into 1 = a bit more top end but less midrange torque!
Lord knows the silvertop needs more midrange torque not less!!
Think about doing what I did when I put a 3sge into my racecar (AA63 rwd Carina).
I got it made as a 4:2:1 with slip joints so I could either:
- extend pimaries
- extend secondaries
- go 4 into 1
This means that if I want to I can tune my exhaust to suit any mods I do to the engine without the mains expense/effort of getting everything remade.
Made by Action Dan in steel then HPC ceramics coated.
Ken
Ham
021 408 863
Postby AceSniper » Mon Jul 10, 2006 4:08 pm
best you could prolly get with out spending ages with R&D is put some blacktop 4-2's on and then re make the 2-1 same length... just better(no squish)
Blacktop head can go on but you would wanna run blacktop pistons aswell, or measure the combustion chamber volumes between silvertop and blacktop an try to get the blacktop close to the volume of silvertop (if you can safly skim that much off)
AceSniper
Postby quicklvn » Sun Jul 16, 2006 10:47 am
ok i'm looking at buying some blacktop extractors now, do they bolt staight on or is there customising to be done?
quicklvn
Postby AceSniper » Sun Jul 16, 2006 2:01 pm
they bolt on, but if you have the time re-pipe the 2-1's that go over the cross member
AceSniper
Postby neo » Mon Jul 17, 2006 2:27 pm
Damn, there some preddddddy extractors Ken!
neo
Postby quicklvn » Mon Jul 17, 2006 5:01 pm
If I put these new blacktop extractors on can I expect any noticable power increase or is it not really worth it? Cause if its not gonna do much then I probably won't bother. :roll:
quicklvn
Postby ROBODISCO_20v » Wed Jul 19, 2006 1:33 pm
A popular mod to do in ozzy on the silvertops is just extend the secondaries. The top half seems to be good enough.
ROBODISCO_20v
Postby Crampy » Fri Jul 21, 2006 12:55 pm
I've seen in the latest NZPC mag some extrators and prices for various cars. The 20V 4AGE ones were $1000 8O 8O 8O
Crampy
