reassurance with offset?
Postby Cakky » Thu Aug 10, 2006 7:52 pm
Ok, so I bought some cheap bz-g rims and had them powdercoated to go onto my ae92 GT corolla, just want to check and make sure that I'm not going to have any problems with offset?
I believe the bz-g offset is 39? I'm sorry for my retardedness, but I just want to make sure I am not going to put these on and then run into problems lol.
and 195/50/15 tyres are the correct size for these rims yes?
thanks lol.
Cakky
Postby ollieboy » Fri Aug 11, 2006 8:23 pm
Well seeming BZG is a corolla and yours is corolla, BZG is fwd and yours is fwd then I would assume they would be fine.
ollieboy
Postby THA SHZ » Sat Aug 12, 2006 9:01 am
dont assume anything like tht , considering they were different offsets 8)
it should work fine as they are only 6.5 wide so should be good , wen u go to 7 inch wide its better to be on 35 offset on the ae82 and ae92 . the only place if its goin to touch will be your rear strut , but with those 15 inch bzg rims you should be sweet 8)
THA SHZ
Users browsing this forum: Bing [Bot] and 18 guests
