W57 Rattle when coming off throttle
Postby beeker » Fri Aug 11, 2006 8:55 pm
W57 Rattle when coming off throttle. Like a type of vibration.
It seems very much from inside the gearbox. You cant feel it through the stick though. Mounts are all good.
Ideas ?
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby NZ_AE86 » Fri Aug 11, 2006 9:59 pm
new problem? changed anything since it wasn't doing it?
solid centre or sprung centre clutch?
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby Silent Knight » Fri Aug 11, 2006 10:06 pm
If not clutch or release bearing it could be the xmember that's getting a tad old maybe and falling apart...?
Silent Knight
Postby beeker » Fri Aug 11, 2006 10:23 pm
Its a recently installed W57 into an AE86. New clutch went in at time of install. X member etc is all solid.
The W57 was purchased 2nd hand, so its a bit of an unknown quantity.
Assuming the noise is from within the gearbox, what would it be ?
06 RS4 Avant
beeker
Postby matt dunn » Fri Aug 11, 2006 10:55 pm
NZ_AE86 wrote:solid centre or sprung centre clutch?
Have you struck that problem too?
Postby NZ_AE86 » Fri Aug 11, 2006 11:00 pm
Yeah, Solid centre clutch = gearbox noise/chatter that is not being dampened so you can hear it when the gears are not loaded.
I have had it in a few cars. Some people can't handle it and have to put a sprung clutch back in!
Current rides;
1986 Levin GT
NZ_AE86
Postby ~SlideWays~ » Fri Aug 11, 2006 11:05 pm
Another simple possiblity is what I had on my w55. The metal cup on the gbox end of the drive shaft/yoke kept coming loose.
Could feel it through the gear lever too.
Didn't figure that one out until I'd taken the lot out! :roll:
~SlideWays~
Postby matt dunn » Fri Aug 11, 2006 11:17 pm
NZ_AE86 wrote:. Some people can't handle it and have to put a sprung clutch back in!
Yup. Struck that in my old EVO.
Put a std clutch in it to sell it as no one would by a car making a noise like that.
Postby Quint » Sat Aug 12, 2006 1:56 am
I get a chatter when i'm acclerating from a high gear from low rpm,, eg acclerating from 20 in 2nd etc. stops after u reach like 30-40.
Might be something diff though (i have no help as to what the hell it is :()
Quint
Postby Ae92typeX » Sat Aug 12, 2006 9:21 am
beeker wrote: ...X member etc is all solid...
Perhaps not what you are experiencing, but in some solid mount boxes ive been in before, a lot of rattle etc is transmitted through a solid x member
Ae92typeX
Postby beeker » Sat Aug 12, 2006 1:55 pm
I think i used the wrong term there, its not a solid mount.
Its all tight and well mounted. It still retains the AE86 gearbox rubber mount.
06 RS4 Avant
beeker
Postby NZ_AE86 » Sat Aug 12, 2006 2:49 pm
So does it have a solid centre clutch or not?
Current rides;
1986 Levin GT
NZ_AE86
Postby beeker » Sat Aug 12, 2006 3:52 pm
NZ_AE86 wrote:So does it have a solid centre clutch or not?
Simple answer is i dont know, but will be asking the question.
06 RS4 Avant
beeker
Postby RS13 » Sat Aug 12, 2006 4:04 pm
Does it only do it on deceleration? My last Cef did that, almost sounds as though theres' a bolt or collapsed bearing inside the gearbox? Is there a fair bit of vibration in the lever, but only on deceleration? I thrashed the tits off mine, with no problems, but it did whine a fair bit as well. Maybe open it up and have a look?
RS13
Postby beeker » Sat Aug 12, 2006 5:24 pm
RS13 wrote:Does it only do it on deceleration? My last Cef did that, almost sounds as though theres' a bolt or collapsed bearing inside the gearbox? Is there a fair bit of vibration in the lever, but only on deceleration? I thrashed the tits off mine, with no problems, but it did whine a fair bit as well. Maybe open it up and have a look?
yes, only when deaccelerating. You cant feel anything through the gear stick though.
06 RS4 Avant
beeker
Postby RS13 » Sat Aug 12, 2006 5:58 pm
Yeah. I'd put my money on a dodgy bearing.
RS13
Postby beeker » Sat Aug 12, 2006 6:20 pm
RS13 wrote:Yeah. I'd put my money on a dodgy bearing.
I've decided to pull it down and do the bearings, so fingers crossed.
06 RS4 Avant
beeker
Postby NZ_AE86 » Sat Aug 12, 2006 6:54 pm
If it has a solid centre clutch I would not waste your time doing the bearings, been there and done that! If it has a solid centre clutch (which you will know when you pull it out) replace the plate with a sprung centre and see if it goes away. If you heard the noises my car makes you would swear I need a new engine/gearbox/diff and suspension too!
Current rides;
1986 Levin GT
NZ_AE86
Postby NZ_AE86 » Sat Aug 12, 2006 6:57 pm
If it has a solid centre clutch I would not waste your time doing the bearings, been there and done that! If it has a solid centre clutch (which you will know when you pull it out) replace the plate with a sprung centre and see if it goes away. If you heard the noises my car makes you would swear I need a new engine/gearbox/diff and suspension too! But these noises are all meant to be there. You just can't hear them in a road car as everything is designed to be smooth and quiet so everything is dampened - springs in the clutch - rubber suspension mounts - smooth LSD's - everything!
Of course if it has a sprung centre clutch then it could well be a bearing! Also your driveshaft may be too long.
Current rides;
1986 Levin GT
NZ_AE86
