4age smallport manifold on 4agze
Postby levinguy » Thu Aug 10, 2006 10:19 pm
has anyone done this?
would think it would flow alot better
just have to move the supercharger and use a different belt?
levinguy
Postby slighty_sykotic » Thu Aug 10, 2006 10:24 pm
Would the effort by worth it though?
Same effort to chuck a bigger pulley on it and increase the boost.
--Sykotic
slighty_sykotic
Re: 4age smallport manifold on 4agze
Postby Rick » Thu Aug 10, 2006 10:31 pm
levinguy wrote:has anyone done this?
Exactly what I have done, the 4agze intake manifold is quite restrictive and with the use of a n/a manifold you can use the n/a throttle body which is larger than the supercharged one. A different belt and a new top mounting bracket will be needed, however this may not work in a fwd setup but in rwd there is a bit of room for the super charger to be on the angle. Also new inlet and out pipes for the the supercharger will be needed
Postby RedMist » Thu Aug 10, 2006 11:27 pm
Which ZE are we talking about?
Either way you would be best matching the NA manifold to the correct head. IE bigport to bigport smallport to smallport.
With a huge step in a mismatched manifold, just before intake valve, you're severely restricting flow.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby bluemaumau » Fri Aug 11, 2006 11:36 am
it depends if your gze in rwd or fwd.
fwd dont bother. rwd heck yea
Postby Santa'sBoostinSleigh » Mon Aug 14, 2006 1:27 pm
(ive got a smallport manifold FS if thats any help ;) )
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Users browsing this forum: Bing [Bot] and 30 guests
