smoke normal in new turbo startup?
Postby flygt4 » Fri Sep 29, 2006 5:03 pm
hey guys.
finally got the new turbo on the car this week. now ive primed the turbo with oil etc and started it up. slight concern is that there is a fair bit of smoke coming from the manifold and turbo when its hot. is this normal when starting a new turbo for the first time?
i was quite liberal with the wd40 when removing the old turbo etc and i suspect it that may be part of it. its definately not steam, it is quite thin white smoke , that increases with revs.
having never started up a new turbo b4 i thought maybe sum1 would know.
i havent driven it yet , ive let it idle for about 10 minutes and it does seem to have decreased significantly , im just unsure as to whether this is normal.
flygt4
Postby Dell'Orto » Fri Sep 29, 2006 5:18 pm
Yeah, there will be a fair bit of oil on the turbo and assorted bits from your skin when you were handling. It'll go away within 10 or so minutes.
Postby flygt4 » Fri Sep 29, 2006 5:33 pm
sweeet it eventually disappeared :D :D :D
maiden voyage was very successful , and it feels a hell of a lot better when its not losing half the boost its making.
flygt4
Postby ~SlideWays~ » Fri Sep 29, 2006 5:54 pm
take meee for a drive! :lol:
~SlideWays~
Postby flygt4 » Sat Sep 30, 2006 10:07 am
haha i had a couple of light runs in it , before i melted the vaccum feed to the BOV and lost all boost :oops: im hopefully gonna pick up some better vaccum line today and have it sorted.
flygt4
