Hey, ive got a ke70 club rally car with a sticky clutch pedal.
It has a 4k and T-50 box with disc brake rear end. It has a solid four puck clutch but i cant rember if the pressure plate is anything special... The clutch plate and pressure plate (reconditioned at the time) have only done about 1000 km ago. Probly only half of that is racing kms.
The problem is when the cars hot and only when the engines running it feels like the clutch cable is grabing or ceasing (sp??). Its fine when the cars cold. and im stalling it all the time when its hot at low revs. At high revs, 4000 plus, the clutch feels fine.
So im thinking either the pressure plate is faulty, the thrust bearings faulty or it has somthing to do with the thrust bearing geting caught sliding up and down.
Any one had any problems like this before? I realy have to get it fixed soon so the box may have to come out anyway.
Thanks
