Oversized pistons
Oversized pistons
Postby TRD_ZERO » Sat Oct 28, 2006 4:15 pm
Can you get oversized GZE pistons From toyota? And if you can, obviously have to bore the cylinders out. What does the cc rating go up to? Is it worth all the trouble and approximatly how much would it cost to get it bored out? All input appreciated..............constructive input that is.
TRD_ZERO
Postby Lloyd » Sat Oct 28, 2006 5:15 pm
Depends entirely what engine its for, how far oversize you want to go and who you get the do the work. Details help
Edit - Oops, missed that you said GZE. I know you can get them 0.5mm oversize as I had some in mine. Not entirely certain if they do other sizes but if Toyota dont stock them then someone else should be able to get you some aftermarket. Bore may depend on how far oversize you wish to go
Postby ATAl » Sat Oct 28, 2006 5:44 pm
Yes, you can get oversize gze pistons, up to 0.5mm over.
Factory bore: 1587cc
0.5mm oversize: 1607cc
It cost me just under $200 to get the block bored and honed.
ATAl
Postby Bazda » Sat Oct 28, 2006 7:27 pm
ATAl wrote:Yes, you can get oversize gze pistons, up to 0.5mm over.
oh I still got ur plenum plates, lol, havent had time to send, but will def do it on monday.
Postby matt dunn » Sun Oct 29, 2006 9:21 pm
I have a set of Brand New Unopened toyota GZE oversize pistons and rings,
and a Block that has been bored out to suit them.
Pistons are 0.5mm o/s and 8.9:1 AE101 GZE,
and the block is an AE101 GZE also so has the inlet for the external oil drain from the head etc etc.
I may not use it now, as the block doesn't fit my 20V sump's,
and may go for some different pistons etc.
PM me if your keen.
Matt
Postby Mr Revhead » Sun Oct 29, 2006 9:55 pm
for the 4age/ze variants toyota do one size o/s and its 0.5mm
