compressing springs while on the car?
Postby moose.cannon » Tue Oct 31, 2006 2:01 pm
I was watching monster garage last night.. lol. and i saw they used a gas torch to heat up the springs on their ride, the ride lowered and when the springs cooled, the ride would stay at that hight.
now i have an old starlet i use as a thrash/paddock car and i wanna lower it and inch or two without having to take the springs out, so it looks sillier and if i happen to get sidways down a bit of a hill there's less change i'll roll the car (again).
I'm trying to thrash this car till it dies (i'll probably die first) and then get rid of it, but the stupid toyota keeps on going lol.
if i do this, i'm curious about how i should go about it. Would you set up two jacks on each side of the car, setting them to the hight you want the car to be, getting the torch and heating the springs so the car lowers to the height of the jacks and then wait for them to cool down? will this even work? is it dangerous? if the car is only lowered an inch or two, will it be very bouncey?
how do I turn this on ?
moose.cannon
Postby JT » Tue Oct 31, 2006 2:40 pm
I'd say the roll would be due to driving/ground conditions, not the springs.
If you must, cutting them is safer and easier to do yourself. Jack it up, compress the springs then get the grinder and cut a coil off. If that aint low enough cut another one off, just cable tie them in once you done. Trim the bumpstops if its bottoming out too often.
JT
Postby Quint » Tue Oct 31, 2006 3:14 pm
Yea, as above, heating up a small section of the spring will help it creep, meaning it will plastically deform (perminatly changeing its shape) though this is a form of work hardening and makes that section of the spring more brittle rather than ductile.
You don't really need me to explain what happens if a spring exhibits brittle behaviour ;)
Take it out, cut it, stick it back in, much safer :)
Quint
Postby RED TOP MR 2 » Tue Oct 31, 2006 4:53 pm
that heating stuff wont be good for anything else in that area e.g brakes.ild cut them personally
RED TOP MR 2
Postby l1ttle_d3vil » Tue Oct 31, 2006 6:22 pm
yea unless you can heat up an entire coil at once to the point it will sag, which I doubt you could do, you would only end up deforming the spring to beyond use.
you can cut springs with a grinder while they are still in the car really easy though.
Postby Pelo » Tue Oct 31, 2006 6:30 pm
That will be your results...
Pelo
Postby moose.cannon » Wed Nov 01, 2006 8:27 am
lol ok cool, thanks guys, i think i'll cut em
moose.cannon
Postby repowered » Wed Nov 01, 2006 9:55 am
moose.cannon wrote:lol ok cool, thanks guys, i think i'll cut em
i saw that episode of monster garage, i was like dodgy heating the springs!
Rollin!
repowered
Postby bad20v » Wed Nov 01, 2006 12:30 pm
Dont heat them...
...get some Makita One Way Adjustables!!!
...cut a coil or two!!!
:lol:
Thank-You.
bad20v
Postby bOi » Wed Nov 01, 2006 6:16 pm
since it is a paddock/thrash car and you are eventually killing it.. just take out the springs :P IMO since the car is "dying" anyways :roll:
bOi
