86' blue-top bolt into a 87' ee80 chassis?
Postby into_obscurity » Fri Nov 03, 2006 8:36 pm
hey guys
quick question
the motor in a mates 1987 gl corolla is almost packed it in. atm it has the 1300 sohc ee80 in it, but ive got this ae82 blue-top from an 1986 fxgt sitting in the shed and was wondering if anyone could tell me if it could be bolted in? and if so, would it be a major?
Cheers! :D
into_obscurity
Postby Zak » Fri Nov 03, 2006 9:12 pm
There was a guy on here that did it to a liftback, as far as I know it wasn't too much hassle. But remember you'll need to do the fuel tank + lines, and you will need a 4age gearbox and probably the half shafts.
It's not really worth doing it unless you have a whole doner car to use.
Zak
Postby Santa'sBoostinSleigh » Fri Nov 03, 2006 10:19 pm
im pretty sure most of the mounts are different, and you will need a cert
so not really worth it IMO
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby KinLoud » Sat Nov 04, 2006 9:40 am
Is the EE80 carby or fuel injected?
If it is carby you will need to sort out efi fuel tank and fuel lines (efi has a fuel return line).
There is some discussion about engine mounts (I don't know which is correct) ... either:
A - the body mounting points are the same for A and E motors and the bits that bolt onto the engine/gearbox are different. or
B - the body mounts are different
A=good. Just get a full set of mounts for the bluetop and gearbox
B= not good. You will have to mod body and/or mounts
Ken
Ham
021 408 863
