New Gaskets?
New Gaskets?
Postby ollieboy » Sun Nov 12, 2006 3:20 am
I had one of my heads acid bathed and all re-done, the only problem I have now is I don't know where to get gaskets from for the end pieces or if they are even available. The bit where the water enters and the other end where its just a hole with a cover. Is it even possible to get these or do you have to make them yourself? I will post pictures tomorrow, imageshack doesn't seem to be working right now. Also, where would I pick up new sparkplug seals, where plug seals onto block? Mine are like plastic. :?
ollieboy
Postby ollieboy » Sun Nov 12, 2006 3:26 am
Oh here they are.
ollieboy
Postby crispy'86 » Sun Nov 12, 2006 7:58 am
If you go into repco, bnt or somewhere to get the full "head set", all gaskets you'll need in there, you'll get the gasket for the flat plate at back of the head and thermostat housing
crispy'86
Postby fangsport » Sun Nov 12, 2006 8:05 am
is it only the 2 end gaskets and plugs seals you need? i probably have some here.
if you need a full head gasket set, let me know as i'll order an extra set when i get mine this week.
fangsport
Postby ollieboy » Sun Nov 12, 2006 2:53 pm
Yep, just the 2 end gaskets and plug seals, I already have head gasket.
ollieboy
Postby ollieboy » Sun Nov 12, 2006 4:26 pm
If you do happen to have them Joe, would you be able to mail them up to me if I pay for postage etc? :)
ollieboy
Postby fangsport » Sun Nov 12, 2006 4:44 pm
i'll have hunt for you and ring you if i find some.
fangsport
Postby tatsumaki » Sun Nov 12, 2006 5:07 pm
Have you tried Revhead?
Support the sponsors of the forum and you'll probably get looked after. :D
PB.
tatsumaki
Postby ollieboy » Sun Nov 12, 2006 11:49 pm
fangsport wrote:i'll have hunt for you and ring you if i find some.
Cheers man.
ollieboy
Users browsing this forum: Google [Bot] and 27 guests
