is ae92 suspension compatible with ae82
Postby escortman » Thu Nov 02, 2006 9:25 pm
im lookin at another ae82 fx
i have the coilovers from my ae92 just sitting in the garage
will these fit in the ae82 im not worried about the top hats i can swap them over if need be but wat about the bolts at the bottom will they still line up
also im goin to buy the ae92 back off insurance so ill have that to pull apart wuld it be worth it to take the rear swaycar setup aswell cause ae92 rear swaybars attach to shock
4x4 toyota blizzard offroader
escortman
Postby Bazda » Thu Nov 02, 2006 9:58 pm
the rear hub pattern is slightly different on the ae82 and the rear top hats are a different pattern on the ae82 so swapping them over would be a good idea.
teh front top plaet is also different so u will need to swap the fronts as well but the bolt pattern to the hubs is the same on the front.
Postby escortman » Mon Dec 18, 2006 8:40 pm
how different are the rear hubs
escortman
Postby Bazda » Mon Dec 18, 2006 8:41 pm
escortman wrote:how different are the rear hubs
the holes are closer together on the ae82. I think it was like 7mm or something.
Postby escortman » Mon Dec 18, 2006 8:48 pm
escortman
