Ae101+Pod? Help
Ae101+Pod? Help
Postby bigfut » Wed Dec 27, 2006 4:28 pm
Hey, I've got a ae101 levin silvertop just in the process of putting a pod filter on. Question though, what should be done to the plug that goes into the factory air box and will this make a difference? Noob :o
http://toyspeed.blakjak.net/profiles/profile.php?id=1702
The Harder You Fall The Higher You Bounce!
bigfut
Postby escortman » Wed Dec 27, 2006 5:00 pm
i think most ppl say dnt go pod just get a upgraded panel filter
4x4 toyota blizzard offroader
escortman
Postby AceSniper » Wed Dec 27, 2006 6:26 pm
odd silvertops dont have air temp sensors.... there in the afm
AceSniper
Postby Loudtoy » Thu Dec 28, 2006 10:06 am
AceSniper wrote:odd silvertops dont have air temp sensors.... there in the afm
Unless he means the plug into the afm which is bolted to the airbox.
Use the search button this has been done a million times and yes it is worth getting a pod for performance if you do it properly and if your not going to do it properly and do a half assed job just get an uprated panel filter to replace your standard one with
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Users browsing this forum: Bing [Bot] and 13 guests
