4agze value
4agze value
Postby shihad » Thu Jan 04, 2007 6:35 pm
simple question whats my 4agze block and head worth?
getting bottled by the friendly Oamaru locals for not doing skids - Coupe Life
shihad
Postby deaf_rattle » Thu Jan 04, 2007 6:40 pm
thats not a simple question
tell us more.
Postby flygt4 » Thu Jan 04, 2007 6:52 pm
ae92/aw11 or ae101?
km's or rebuilt?
assembled or in bits?
running or run bearings/broken in some way?
flygt4
Postby Lloyd » Thu Jan 04, 2007 7:45 pm
While on this subject, how bout for this too?
4AGZE block (late model AE92, oil squirters etc, surfaced, 0.50mm overbore)
4AGZE crank
New Toyota GZE rods
New Toyota 0.50mm oversize 8.9:1 GZE pistons
New Toyota rings, bearings etc etc
New clutch with modified pressure plate (~50% heavier)
All balanced including clutch
Silvertop head, standard, surfaced
Silvertop quad throttle bodies
Custom made tapered stainless RWD plenum
Has been run for a hundred kms maybe, not long anyway.
Dont think I need it anymore, not sure what its worth though
Postby l1ttle_d3vil » Thu Jan 04, 2007 8:10 pm
yes, definitely need more info. i picked up an aw11 4agze, cut loom, no ecu, supercharger or flywheel but with everything else for $600. and that was kinda mates-rates.
Postby flygt4 » Thu Jan 04, 2007 8:36 pm
people want too much for these nowadays. munters ask too much for em on TM and then wonder why they dont sell, its because you could usually build an engine from scratch for not much more money, and then you know exactly whats been done.
HRT , that sounds pretty similar to the specs of my engine,minus arp fasteners and TRD HG. have you got receipts for any interested seller? that always helps a lot.
flygt4
Postby Lloyd » Thu Jan 04, 2007 9:32 pm
Haven't got any reciepts, wasn't planning on needing them :P Pistons and rods etc were off trademe or from someone on here from memory, still in the Toyota boxes. Machine work done as cash stuff, Silvertop for parts was just from a mate for cash, plenum was made by my workmate
